1995 lexus es300
1995 LEXUS
PJENT
I have a 95 lexus es300 that runs hot only when you turn on the a/c. Runs fine and at normal temp. as long as you don`t turn on the a/c. It has a new radiator and a new thermostat. What are any other problems that can cause this?
Jun 17, 2006 at 4:02 PM
J.P.
  • 20 POSTS
Stupid Question, but have you checked to see if the electric fan (if equipped) turns on when you turn the A/C on? I'm not too sure how Lexus operates, but usually there are electric fans that help keep the car cool once the A/C turns on or when the Car reaches a certain temp...... If you notice it doesn't come on, check for fuses if they are fine then try jumping the fan to a constant power source (battery) and if it turns on then there is a bad thermo sensor....hope this helps..
Aug 20, 2006 at 2:15 AM
