1993 Lexus LS 400 Speedometer won't work all the time
1993 LEXUS LS 400
200,000 MILES • V8 • 2WD • AUTOMATIC
JOE5005
So I recently bought a 93 Lexus from one of my dad's friends. Everything runs great, except, about every other day, the speedometer won't work, along with the RPM gauge. Now this wouldn't be a big deal to me, but in my town, cops are strict, and will hand out tickets left and right.
1) What could be causing this?
2) How much would it cost to have this fixed?
Thanks.
Jul 18, 2008 at 7:03 AM
KHLOW2008
  • 41,814 POSTS
hi JoE5005,
If it is only the speedometer, it could be the speed sensor.
Coupled with the tachometer, I would suspect a poor wire connection somewhere or a faulty meter circuit board.
When the speedometer does work, is the tachometer working or both fails at the same time?
Sorry to say that I am unable to provide any costings.
Jul 20, 2008 at 7:33 AM
JOE5005
Yes, it is paired with the tachometer. Both work at the same time, then both do not work at the same time.
Jul 23, 2008 at 5:53 AM
KHLOW2008
  • 41,814 POSTS
Hi JoE5005,
Sorry for the late reply.
If both are paired when working, then it could be a bad power supply which might be from a poor ignition switch contact. however this should also affect other items like dash indicator lights etc.
If it is not a power supply issue, then you need to replace the control unit in the meter cluster.
Jul 29, 2008 at 9:42 PM
