2003 Lexus GS 300 Unknown noise source
61,000 MILES • 6 CYL • 2WD • AUTOMATIC
JUSTKEN
I own a used Lexus GS 300 with 61,000 miles on it. Recently it has started making a noise in two instances:
(a) after first starting the car, I will step on the brake to move the transmission into R from P. The car will move slightly under power and make a "clunk" sound.
(b) this sound also occurs when applying the brakes and making a turn (especially right hand).
The sound doesn't occur when slowing to a stop in a straight line. I took the car to a mechanic and he agreed he could hear the noise but was unable to pinpoint the source.
Any ideas?
Best regards!
Jul 16, 2008 at 3:01 AM
DOCFIXIT
  • 18,828 POSTS
Check the motor mount on the front of the engine. Also check the right side strutt mount.
Jul 16, 2008 at 3:35 AM
  • 75,988 POSTS
Have the curb idle speed check and for the clunking check the center support bearing and U joint/s
Could be the CV joint/boot
Jul 16, 2008 at 3:43 AM
