left rear wheel will not bleed no fluild or air
75,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JEFF CORBIN
right rear brake line got a leak, so i replaced about five feet of line. leaked all of fluid out master cylinder, all whee ls will bleed, but not the left rear nothing comes out. please help. also, no pedal when started and pumped.
Aug 6, 2016 at 11:04 AM
WRENCHTECH
  • 20,758 POSTS
The bleeder is likely plugged up. Remove the bleeder and take a small drill and run it down to the bottom of the bleeder to clean out any rust inside of it.
Mar 11, 2021 at 5:50 AM
JEFF CORBIN
thank you for your help the brake line was rusted solid
going in to my brake clylinder so i replaced the short line and clylinder an that worked thank you for the help
WRENCHTECH
  • 20,758 POSTS
You're welcome
