Left indicator needs pressing down hard to operate, then sometimes is perfectly fine
47,800 MILES
MICHELLE GILDER
My left hand indicator intermittently needs pressing down hard to make it work. Obviously after a week of this happening continuously, when I took it into VW it worked just fine! Now it is happening most days, with bursts of it working okay (with just the usual flick down).
Any ideas please?
Jun 7, 2017 at 5:58 PM
SATURNTECH9
  • 30,869 POSTS
Sounds like a bad turn signal switch. they just want to verify the problem so they can make sure that is what it is. I do not blame them.
Jun 8, 2017 at 12:02 AM
MICHELLE GILDER
I am not blaming anyone, I just want to know what the problem might be?
Jun 8, 2017 at 12:18 AM
SATURNTECH9
  • 30,869 POSTS
Without verifying the problem and seeing what is going on it is hard to say what the actual problem is. Lets just say they said, oh I think it is a bad turn signal switch and replace it. Of course they charge you and it is not going to be cheap to do. Then it happens again your going to go back and really complain you paid a lot of money to fix the problem that is not fixed. So now there going to have to stand by the repair and fix the true problem. I would not feel comfortable just saying it is a bad turn signal switch without seeing it happen, there could be even having to disassemble things to see what is going on. I especially would not want to do that if it was not happening. If I did not find anything then I might have to go in there at a later time. That is the best most honest answer I can give you on this problem.
Jun 8, 2017 at 1:14 AM
MICHELLE GILDER
Thank you, you have been most helpful. ?
Jun 8, 2017 at 1:18 AM
  • 55,647 POSTS
It does sounds like the turn signal switch needs replacement. Here is a guide that will show you what you are in for when replacing the switch.
https://www.2carpros.com/articles/turn-signal-switch-replacement
Cheers, Ken
Jun 8, 2017 at 3:26 AM
MICHELLE GILDER
Now that, my friend, was helpful! Thank you so much.
Jun 8, 2017 at 3:41 AM
  • 55,647 POSTS
Please use 2CarPros anytime, we are here to help. Tell a friend please.
Cheers, Ken
Jun 8, 2017 at 5:55 AM
