LED fog light not working
656 MILES • 6 CYL • 4WD • AUTOMATIC
JEFF PALASKI
Three weeks new and my passenger side fog LED light does not work have anyway I could check for the problem.
Nov 12, 2018 at 3:24 AM
  • 110,251 POSTS
Are you replacing the bulb with the manufacturer's recommend type bulb? Next, and most commonly, when a bulb fails quickly, it is due to moisture. Check and inspect the lens and assembly for evidence of moisture. Also, you indicate the bulb was LED, I believe this vehicle comes with either an H3 or H11 bulb, both of which are halogen and not LED.
Let me know what you find.
Nov 12, 2018 at 11:03 AM
