You
I have a 2006 Cadillac Escalade. The check engine light keeps coming on with the two lean codes p171 and p174. I took it to a Cadillac dealer. $4000 dollars later they found the MAF sensor loose and reseated it. They tested it and found both long term fuel trims back to 25%. They swapped the sensor, no change. They unplugged the sensor and purged the valve. Long term fuel trims to 5% and 8%. Smoke tested intake system. No leak. Pressurized the intake sytem, no leaks. Fueled the car for long term fuel trims and it is at 15% for both banks. They heard a whistle on a cold start around 1800 rpms. They replaced the intake manifold and gaskets. They performed a fuel injection system device and reset fuel trims. After a road test the codes returned. They smoke tested the exhaust. They found the the oxygen sensors go rich in both banks. The sensors function normally. They tested the fuel and found fuel trims base line at 8 to 9%. They drained the fuel system and refilled with fresh fuel. Cleared codes and reset fuel trims. Road tested again and found long term fuel trim at 21% on highway, 16% on idle. They reprogrammed the PCM again. No change. They installed a known good bank one sensor and an oxygen sensor, no change. Swapped a PCM and no change. Performed an injector balance and all tests good. Performed an exhaust pressure test and found both side manifolds are leaking. At this point they had the car for over a week and the expense was more than I can handle. Can the codes really be coming from the exhaust manifold and should this have been so hard to diagnose?
Feb 12, 2019 at 11:54 PM
