1999 Land Rover Discovery 2
JACK MERDOCK
  • 1999 LAND ROVER DISCOVERY 2
  • 4 CYL
  • 4WD
  • 167,000 MILES
How to chnage water pump?
Friday, September 3rd, 2010 AT 9:42 PM
DAVE H
  • 13,384 POSTS
WATER PUMP
NOTE:Note bolt length and location during removal. Different length bolts are used and must be installed in original location.
Drain cooling system. Loosen 3 water pump pulley bolts. Remove auxiliary drive belt. Remove water pump pulley. Remove coolant hose from water pump. Remove water pump. To install, reverse removal procedure. Tighten bolts to specification.
Sunday, September 12th, 2010 AT 6:03 PM
