1999 Land Rover Discovery
SBAYTOP
  • 1999 LAND ROVER DISCOVERY
Something is draining my battery down after about 20-30 minutes of driving, I have to charge them everyday at work and at nite when I get home, and sometimes when I have to pull over and change it out, I get nothing, i'm wondering if it could be a bad connection somewhere. I changed the belt on the alternater because it was to big for the alt
Monday, February 8th, 2010 AT 10:12 PM
  • 31,937 POSTS
Hi there,
You will need to get a current draw test don on the entire electrical system, if your mechanic is not sure how to do this test, re post for instructions, this will help locate and open circuit that is drawing current and causing the battery to die, also have a load test done on the battery to prove its condition.
Mark (mhpautos)
Tuesday, February 9th, 2010 AT 4:11 AM
