lacks power, acts like it isnt getting enough fuel
257,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
CSA1
  • 78 POSTS
truck runs like crap. acts like it isnt getting enough fuel to throttle body. Engine only has 14.000 miles on it. have replaced fuel pump, ignition module, has a fairly new throttle body, just replaced TPS & MAP & EGR
fuel filter was changed when pump was, ( bout 6 months ago)
It will drive down road & act fine for a little bit, then it loses power, but sometime you can stomp the gas 7 it acts fine again for a little while. has me stumped. we pulled the codes on it, showed 44 ( lean mixture on O2 sensor) Only thing I havent changed is the EGR solenoid & idle air. any suggestions?
Nov 11, 2015 at 6:04 AM
DOCHAGERTY
  • 9,606 POSTS
C
Plugged cat is my guess
Nov 11, 2015 at 11:35 AM
CSA1
  • 78 POSTS
Cat was removed a couple years back
Nov 11, 2015 at 3:19 PM
CSA1
  • 78 POSTS
found the problem.. Injector on left side, facing engine in throttle body was not spraying. wiggled it & it started spraying again, going to go get a new connector, as think that one has a short in it
Nov 13, 2015 at 2:06 AM
