Lack of oil
102,000 MILES • 3.4L • 4 CYL • 2WD • AUTOMATIC
SLDAWSON1989
My daughter drove her car without oil for approximately 3-5 total. Started grinding and drove straight home. We added oil and it ran it for a few minutes, let it sit for several hours, then started it again. Sounded better but not great. Drove it a very short distance and accelerating did sound good, and we were going very slow. Pulled into driveway. We noticed no leak or dripping but found oil in all wheel wells and on the outer rim of tires. Did she just mess up her engine really badly?
Feb 18, 2022 at 4:52 AM
SQM
  • 6,383 POSTS
Generally speaking, driving without oil or very little oil can permanently damage the engine. As it will create hot spots in the engine due to friction. The engine can even seize up due to excessive friction and heat.
Your fist step would be to find where the leak is coming from. After the leak is taken care of then you can add oil and try some engine oil additives to see if that helps.
Take a look at this guide, it covers the typical oil leaks:
https://www.2carpros.com/articles/engine-is-leaking-oil
Now if there is permanent damage to components it will likely need rebuilding or replacement. This type of damage will lead to noisy engines and other issues.
I have seen oil leaking out due to having a loose oil filter or drain plug after an oil change, so might want to check the filter.
Let me know what you find or if you have any questions.
Feb 18, 2022 at 7:18 AM
