Knock sensor
230,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
You are welcome.
Nov 8, 2018 at 8:07 AM
RCA195203
  • 69 POSTS
Roy, I got the fuel pressure test done and it was 47 and dropped to 45 but did not go down anymore. I hit the gas a few times and it did not go any lower. The book says 55/61.
Nov 9, 2018 at 5:53 AM
That is correct. You need a fuel pump.
That will make a good difference in the running.
Nov 9, 2018 at 6:11 AM
RCA195203
  • 69 POSTS
I just replaced the whole thing in June.
Nov 9, 2018 at 7:52 AM
Does not matter if you replaced it yesterday. You need a pump.
Nov 9, 2018 at 8:10 AM
RCA195203
  • 69 POSTS
Why would the live data say that O2B1S3 when I only have one sensor on bank 1?
Nov 9, 2018 at 8:11 AM
Do not worry about that as there is no sensor 3 anywhere.
That is the tool.
Nov 9, 2018 at 8:13 AM
RCA195203
  • 69 POSTS
Okay.
Nov 9, 2018 at 8:19 AM
It should be under warranty if you replaced it in June.
Nov 9, 2018 at 8:41 AM
RCA195203
  • 69 POSTS
Bought it on eBay, but I will look into it. Thank you
Nov 9, 2018 at 10:04 AM
You are welcome.
Try rock auto they have warranties that they stand behind.
Nov 9, 2018 at 5:10 PM
RCA195203
  • 69 POSTS
I will look into it. But let me ask you a question, if it is the pump, then why do I not have any problems starting in the cold mornings? Most of what I see on bad pumps shows a long duration of start time before starting, mine starts really quick. And what does the pump have to do with my timing being off like it is?
Nov 10, 2018 at 12:52 AM
The pump has enough pressure to start but does not supply enough fuel to the injectors and the ECM sees that. That is why it is running lean.
The long term trims at 25% are the key. Running very lean.
Nov 10, 2018 at 4:51 AM
RCA195203
  • 69 POSTS
Roy, seeing as though my timing is off as it is, would that or a low voltage at the pump cause my readings to be low?
Nov 10, 2018 at 6:09 AM
Forget the timing, we are way beyond that issue.
Yes, low voltage could do it but I doubt it very much. There would be other issues if that was the case.
Nov 10, 2018 at 6:13 AM
RCA195203
  • 69 POSTS
Well, I guess so I guess that is it then! Winter is setting in and I work on it outside, so I will have to wait until spring to pull the bed and the pump. Thanks for the help.
Nov 10, 2018 at 7:42 AM
You are welcome.
Nov 11, 2018 at 10:53 AM
