2003 Ford Escape Knock Sensor Missing
The sensor is near the rear of the engine, here is a wiring diagram for the engine and knock sensor and a location picture of the sensor (BELOW). Look for the color wires that will match up. Nice work on pulling the engine. Please let us know what you find ;)
What year and engine is your Escape?
I am going to attach a little different info from a different manual then above.
The Duratec and Zetec engine do have different locations and pin in the PCM.
If you are not sure if you have the 2.0L or 3.0L then if you send your VIN, we can determine that.
Do you have a wire in pin 87 of the PCM? What color is it?
Let's start with this and go from there.
Do you have any codes? If the PCM is looking for the info on this circuit then it should be setting codes for open circuits or other issues because it is not seeing it.
Thanks
Suggested Repair
Trace the PCM connector rather than assuming the knock-sensor plug was cut. On the 3.0L Duratec, pin 57 should be yellow/red and pin 32 dark green/violet to the knock sensor; pin 87, often red with a black stripe, goes to an oxygen sensor. If pins 32 and 57 are empty, the knock sensor was omitted on that vehicle. Confirm the engine and scan for open-circuit codes if the PCM expects the signal.
Conversation Summary
A 2003 Ford Escape owner could not find the knock-sensor connector after installing the engine and asked whether the right-side harness from the computer was the correct circuit. Experts supplied engine wiring diagrams, sensor location guidance, and PCM pin colors, and asked for the engine type, VIN, pin 87 color, and any codes. Follow-up confirmed a 3.0L Duratec with empty pins 32 and 57 and a red/black wire at pin 87. The expert said those empty pins mean the knock sensor was omitted, while pin 87 serves the oxygen sensor.
