Transmission goes into neutral
WILLIAM19792
  • 1996 CHEVROLET LUMINA
  • 3.1L
  • 6 CYL
  • 260,000 MILES
I'm driving down the road an my car is fine, then all of a sudden it will kick out of gear. Sometimes I give it a little gas and it will be fine. It causes my speedometer to go haywire too. I have to give it gas an let off a few times sometimes before it corrects. Sometimes I have go pull over completely an start my driving over from a parked position. I can't figure out what may cause this.
Wednesday, May 1st, 2019 AT 5:54 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,643 POSTS
The first thing I would do is check the transmission fluid level here is a guide to help you. It sounds like the VSS might be going bad.
Lets run the codes as well
Thursday, May 2nd, 2019 AT 2:05 PM
