2008 Chevy Lumina transmission
2008 CHEVROLET LUMINA
148 MILES • 6 CYL • 4WD • AUTOMATIC
RTYU789
I push down on the gas pedal and the car was going very slow and I felt a tremble and the speedometer went to 30 mph and the car was not catching up. Eventully the car caught up with the speedometer.
Apr 20, 2010 at 7:02 PM
  • CAR REPAIR CONTRIBUTOR
Tranny could be slipping if not check and test the following below.
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Apr 21, 2010 at 6:57 AM
