2004 Kia Spectra Strut Replacement
46,000 MILES • 4 CYL • FWD • AUTOMATIC
NIGHTWOLPH
I was told the rear struts were leaking and the rear tires "cupping". I never seen any leaks coming from the vehicle (other than when the a/c is on) and have not notice any difference on the rear tires or the way it drives. Do the rear struts need to be changed or can they be repaired? I was quoted $560 for the service and parts, isn't that kind of high?
Sep 7, 2010 at 8:35 AM
  • 110,251 POSTS
Take a look at the strut. You will see oil on it if there is a leak. Also, do the bounce test. Bounce the vehicle and if it stops within 3 bounces, the struts should be okay.
Now for the tires. Lightly run your hands over the tire to see if there is any cupping.
Let me know what you find.
PS: I don't know where you live, but the price is somewhat high.
Oct 18, 2010 at 2:36 AM
