2004 Kia Spectra lost power to door lock, dome light, clock
2004 KIA SPECTRA
144,000 MILES • 4 CYL • FWD • AUTOMATIC
SIDNEYKI
The battery drained down two time and the car would not start. had battery and alt tested. they where good.
having electrical problems. I check the fuses with a volt meter and they tested good.
The radio, the remote entry, dash clock, dome light, map light, door light will not come on. The door lock will only work when the car is on.
some kind of power problem with part of the electrical system.
I tryied to look for any recalls but did not see any electrical recalls.
Any Suggestions what to replace/fix ?
Jan 27, 2008 at 11:09 AM
DAVE H
  • 13,384 POSTS
check all underhood fuses as well ?
Apr 11, 2009 at 3:06 AM
STLUNITICS
Did you ever figure out what was causing the problem? im having the same issues with my kia.
Mar 23, 2011 at 8:14 PM
