Engine Power Loss?
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
SKRAMSEY
While driving around town the Sorento does great, but while I am on the interstate travelling 65-70 MPH, It seems to lose power and slow down, and will not accelerate. If I pull over and startup it does fine until reaching those speeds again. What might my problem be?
Jul 13, 2009 at 9:25 AM
  • 110,248 POSTS
I would check two things. First, make sure the fuel pressure is good. Here is a How to:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
If it is good, have the catylatic converter checked to make sure it isn't plugging. Also, I am assuming that the check engine light isn't on. If it is, let me know.
Sep 1, 2009 at 2:05 PM
  • 110,248 POSTS
I'm sorry, but they never followed up. Is your vehicle the same year make and model? Does it have the same size engine?
If so, have you checked the fuel pressure? As mentioned above, that is where I would start. If the fuel pump can't keep up, what was described can happen.
Mar 17, 2023 at 12:23 PM
