rough idle
KIA
NEVER00ENDER00
my car has had a loss of power, running sluggish, that sort of thing.
so i had the spark plugs replaced, and had to replace my radiator hoses just due to a minor leak.
after about driving for 20 minutes after having replaced the plugs, my check engine light came back on.
now when im sitting at a stop light or the car is idleing, it is really rough, the car actually seems to shake quite a bit. after you accelerate it seems to be fine, but it will cut out of power a lil bit on hills, it actually seems like it has trouble getting into 3rd gear or higher.
i was just trying to see what else i should look into, i had the shop run it through the computer, and they said it seemed fine.
after i left not 10 minutes later it started and the check engine light came back on.
the only thing i can think of really at this point is maybe the oxygen sensor?
besides having like (advanced auto parts) run a diagnostic, what else should i try?
the mechanic seemed to just blow me off, after i just paid for them to do absolutely nothing.
please any advise would be helpfull.
thanks
Mar 8, 2006 at 8:33 AM
2CARPRO JACK
  • 11,533 POSTS
Need to know the code. Sounds like a possible random cyl misfire. Did this start before the "tune up" Be sure the plug wires are on securely and that OEM parts were used
Apr 6, 2006 at 10:28 AM
CODY-ODY
  • 57 POSTS
Start with the "engine light" and go from there otherwise your wasting time and money!
Jun 18, 2006 at 1:56 AM
