1995 Kia Sportage Hesitation
When I bought it @ 109k miles it had jumped time so the resulting damage was a broken piston, broken off valve, and a torn up head. Luckly the cylinder wasn't hurt so after a good honing, new piston/rings, and a brand new (not reman) head, it was running and now has 116k. When I got it running there was no hesitation until around 114k then it started. So to answer your question, it only had 5k on a brand new new head when this started however over a period of a month I ran three cans of seafoam injector cleaner through it which would also clean the valves but it made no difference. Oh, when this started I also checked the valves and clearance was good. So, in all I've checked the valves clearance, replaced the fuel filter, fuel pump, plugs/wires/air filter, replaced throttle position and maf sensor, three cans of seafoam injector cleaner, checked manifold vacuum which is good/no leaks, cleaned throttle body.........and I'm out of ideas yet it still stumbles/hesitates.
quote="Service Writer"]Did you clean the intake valves at all?
There was a recall campaign for the cat. converters. Typically with a recall for emision or saftey, it will go beyond the normal warranty period. IT was regarding internal deterioration. May be worth a call to the dealer.
You can disconnect the exhaust to check for restrictions.
Measure the vacuum at the manifold it should be more than 17.7 Hg
Check the MAF voltage.
At idle it should be 1.8 to 1.2V and
at increased idle it should be 3.5 to 4.0V
Re-check the fuel pressure for spec.
With engine speed at Idle (750-850 rpm) and pressure gauge connected between fuel inlet hose and fuel filter, is should be at 34 psi. With the vacuum hose disconnected at pressure regulator is should jump to 42 psi.
IF all of the above checks out good, then you'll need to go to checking the in voltage at the ecm.
Suggested Repair
Do not assume replaced parts are good. Check manifold vacuum (above 17.7 in Hg), ask a dealer about the catalytic converter recall and test for exhaust restriction, verify MAF voltage, and recheck fuel pressure (about 34 psi at idle, rising to about 42 psi with the regulator vacuum hose disconnected). If those checks pass, test voltage at the ECM.
Conversation Summary
A 1995 Kia Sportage with 116k miles hesitates and idles slightly rough despite replacement of the fuel pump, filters, plugs, wires, throttle-position sensor, MAF sensor, and PCV valve, plus throttle-body cleaning, EGR and vacuum checks, and injector cleaner. The engine had earlier timing-related piston and head damage that was repaired, and the hesitation began after about 5,000 miles on the new head. The expert recommended verifying vacuum, catalytic-converter restriction, MAF voltage, and fuel pressure before checking ECM voltage.
