2002 Kia Optima Alternator Keeps Failing
2002 KIA
LAINHART3
I have a 02 kia optima that the battery light came on and we replaced the alternator and it started running again but the alternator went out again so we replaced it again because I got a used one. I replaced the used one with another used one but this one only lasted about a month. What would make the alternators go out so often I believe it has to be something other than that they just keep wearing out but I could be wrong.
Sep 3, 2006 at 1:11 PM
SYNCRAIT
  • 235 POSTS
are you doing the work yourself and are you getting the alternators tested when your bringing them back in the store.... when you replace the alternator it is also a good idea to replace the belt too because if the belt is streched the alternator dosent get the rpms needed to keep the battery charged....also put your battery on a charger for a night so the alternator isnt working with a dead battery which can also burn out an alternator.....good luck :)
Sep 3, 2006 at 10:45 PM
Suggested Repair
Have replacement alternators tested before installation, replace a stretched drive belt so the alternator turns at the proper speed, and fully charge the battery overnight so a dead battery does not overload the new alternator.
Conversation Summary
The owner of a 2002 Kia Optima says the battery light came on and several replacement alternators, including used units, failed within about a month. The expert advises confirming that returned alternators are tested, replacing a stretched belt that may underdrive the alternator, and charging the battery overnight so the alternator is not forced to recharge a dead battery.
