2001 Kia Optima Hard Shifting
KIA
FLUSSITA
2001 KIA Optima 2.5 liter
When car is shifting between 2nd and 3rd and/or 3rd and 4th it will hestiate or stay at same RPM and then lurch into the gear with a klunk sound - sorry for the descriptive words or lack thereof.
Had this repaired about a year ago 43,000 miles. I feel same problem again at 56,000 miles.
First repair was replacement of input shaft speed sensor. DTC P0715 code found.
This time they've recommended to reprogram TCM stating only "verified concern" - no codes listed or really what they did to "verify concern." The warranty company will not cover reprogram of TCM.
Any advice on further steps or maybe an explanation of what reprogram TCM entails?
Thanks for any help!
Any advice?
Jan 20, 2007 at 8:34 AM
2CARPRO JACK
  • 11,533 POSTS
I have repaired a few KIA trans problems that were simply poor connections at the TCM. Have aall the connections checked at the trans plug and the TCM plug before having anything else done...... good luck
Jan 22, 2007 at 11:52 PM
Suggested Repair
Before reprogramming the TCM, inspect and clean all connections at the transmission plug and the TCM plug. Poor connections have caused similar Kia transmission shifting problems.
Conversation Summary
A 2001 Kia Optima 2.5L hesitates and then lurches with a clunk when shifting between 2nd and 3rd and/or 3rd and 4th. An input shaft speed sensor was replaced about 13,000 miles earlier for DTC P0715. The shop now recommends a TCM reprogram after verifying the concern, but no codes were listed and the warranty company will not cover it. The expert advises checking all connections at the transmission plug and TCM plug before any further work.
