1999 Kia Sephia No Fuel Pressure
1999 KIA
ANOSAL
55,000 miles
The car has had some trouble starting but now it does not start at all. I attached a pressure gauge to the fuel rail and I do not receive any pressure when I turn the key to the on spot, or when I try to start the vehicle. All the fuses are good. The fuel pump and filter were replaced recently and the car functioned for a couple of months after that with good pressure readings. There is voltage traveling to the fuel pump. Each spark plug wire produced a spark when I used a spark tester. What would you recommend I check next?
Aug 28, 2007 at 10:20 AM
SERVICE WRITER
  • 9,123 POSTS
IF you don't have fuel pressure, check to see that power is getting to the pump. If it is, the pump went south.
Sep 20, 2007 at 12:27 AM
Suggested Repair
Confirm that power is reaching the fuel pump. If power is present and there is still no fuel pressure, the fuel pump has failed and should be replaced.
Conversation Summary
A 1999 Kia Sephia with 55,000 miles will not start and shows no fuel pressure at the rail with the key on or while cranking. Fuses are good, spark is present, the pump and filter were replaced recently, and voltage reaches the pump. The expert advises verifying power at the pump and treating the pump as failed if power is present.
