2002 Kia Sportage Gas Smell
KIA
MCNABBL
Just bought a used 2002 Kia Sportage, 63K mi, smelled gas really bad inside, took it back to dealer, they replaced all fuel injector hoses and orings, still smell it sometimes when heater is on, mostly notice it when I come to a stop. It smells in front, not in back. Do new orings and hoses take time to break in, should I give a couple more days? Also, I now here a squealing, almost alarm sounding, noise from the engine, someone told me it could be my water pump going out, and another told me it could just be that some belts need dressed...what do you think? I've only owned it for a little over 2 weeks and have only had it in my possession for about 1 week, have I been had? AGH!
Nov 13, 2006 at 7:36 AM
BRUCE HUNT
  • 3,754 POSTS
The fuel smell should dissipate with time unless they have not found the source.
The squeeling most likely is the belts and that they have not been tensioned properly OR they have become glazed and need replacing.
Nov 13, 2006 at 7:43 AM
Suggested Repair
The cabin fuel smell should fade if the injector hoses and O-rings were the source; if it continues, the leak has not been found and needs further diagnosis. The squeal is most likely a belt that is loose or glazed—check tension and replace glazed belts rather than dressing them.
Conversation Summary
Owner of a recently purchased 2002 Kia Sportage with 63,000 miles reports a strong gas smell inside the cabin, mainly in front and when stopping or using the heater, after the dealer replaced fuel injector hoses and O-rings. A new engine squeal was also noted, with suggestions of a failing water pump or belts needing dressing. Expert advice is that the fuel smell should dissipate unless the source was missed, and the squeal is most likely improperly tensioned or glazed belts that need replacement.
