Brakes problem
1996 Other Kia Models 4 cyl Four Wheel Drive Manual
I change the breaks and master cylinder on my kia ceres truck, my break pedal is hard when engine is not working, but when engine is started the break pedal goes to the floor and that is where the breaks constantly holds, floor. I bleed the breaks numberous times , with the engine started also but the same result, is it a possibility tha my proportioning valve is bad or going bad. I am desperate to have this problem solved.
Jul 24, 2010 at 2:13 PM
