1998 Kia Sportage Brake Odor After Repair
KIA
SHUTTERBUR
I just had the Cylinders, shoes, and pads replaced on the rear breaks of my 1998 KIA Sportage. They also re-sized the drums and removed the air from the break line. The car is running fine, but when I was driving the other day I knoticed a little odor from the new breaks. The conditions that day were really bad, a lot of snow on the ground and slippery. My parents say there is nothing to worry about, that they are "buring" through the film on the breaks. A problem that occured on my parents explorer that had breaks done the same day. Any thoughts.
Jan 20, 2006 at 10:21 AM
2CARPRO JACK
  • 11,533 POSTS
sounds good to me
Jan 24, 2006 at 9:34 AM
VANDRAGON
  • 298 POSTS
kia brakes run too tight and heat up. when you drive threw cold deep water or snow they create steam, sometimes warping the rotors. kia had a recall about this problem about 5 months ago. not sure if it includes your car or not. call dealership.
Mar 20, 2006 at 6:15 AM
Suggested Repair
The slight odor is likely normal break-in of the new rear brake friction material. Because some Kia brakes run tight and can overheat, steam, or warp in snow or cold water, call a Kia dealer to check whether a related brake recall covers this 1998 Sportage.
Conversation Summary
The owner of a 1998 Kia Sportage noticed a slight odor from newly replaced rear brake shoes, pads, and cylinders after driving in snow. One expert agreed this can be normal film burn-off. Another said Kia brakes can run tight and overheat in snow or cold water and advised calling the dealer about a possible recall.
