Brake vibrating when idling in gear
2011 KIA
54,059,294 MILES • 3.5L • V6 • 2WD • AUTOMATIC
BAKHTIAR DUSKY
  • 96 POSTS
Hello guys, my car has a problem with vibrating on braking when on idle in drive and when the car is stopped. However, when is in neutral it works fine. thanks
Oct 31, 2016 at 3:50 PM
SATURNTECH9
  • 30,869 POSTS
Sounds like you have a worn engine and or transmission mounts. What is the actual mileage on the car?
Oct 31, 2016 at 4:15 PM
BAKHTIAR DUSKY
  • 96 POSTS
Almost 54,680 miles. The vehicle does not make any noise it just vibrates when I stand still at traffic light etc. But when I switch to neutral it goes away .
Oct 31, 2016 at 4:31 PM
  • 55,647 POSTS
It definitely sounds like and engine mount that has collapsed. Raise the car and use a flashlight to check the engine and transmission mounts, you should be able to see one that is torn or worn down.
Please let us know what you find so it will help others.
Best, Ken
Nov 1, 2016 at 2:41 AM
BAKHTIAR DUSKY
  • 96 POSTS
Thanks for the replay guys, but may I know what is mounts?
Nov 1, 2016 at 2:55 AM
  • 55,647 POSTS
These are the parts that have a rubber insulator that support the engine and transmission. When the engine is running it vibrates the engine and transmission mounts shield the car from this vibration.
Nov 1, 2016 at 3:31 AM
BAKHTIAR DUSKY
  • 96 POSTS
Oh I see thanks, and it is critical to replace it immediately when it happen? Or does will it make a serious damage?
Nov 1, 2016 at 3:33 AM
  • 55,647 POSTS
It can cause damage if let go too long, it depends on how bad they are worn and broken. Inspection is required.
Best, Ken
Nov 1, 2016 at 3:52 AM
BAKHTIAR DUSKY
  • 96 POSTS
Okay man, thanks I will check it and post the results.
Nov 1, 2016 at 4:05 AM
SATURNTECH9
  • 30,869 POSTS
Yes, eventually they will tear free and can damage other mounts etc over time.
Nov 1, 2016 at 5:28 AM
BAKHTIAR DUSKY
  • 96 POSTS
hey guys it was due to Transmission mount but they said we dont have the genuine one and i didnot want them to put the none genuine one .so i will have to wait till they get the genuine one .but i dont know if its bad to let it till it get here i mean its not as bad as if it was the Engine Mounts right ?
Nov 5, 2016 at 7:27 AM
SATURNTECH9
  • 30,869 POSTS
I have used aftermarket mounts before and haven't had any issues verus factory ones.
Nov 5, 2016 at 10:05 AM
BAKHTIAR DUSKY
  • 96 POSTS
oh i see so its not that important to install the Genuine one ?
Nov 5, 2016 at 6:38 PM
SATURNTECH9
  • 30,869 POSTS
No it's not.
Nov 5, 2016 at 6:56 PM
BAKHTIAR DUSKY
  • 96 POSTS
Ok thanks guys for the help and tips
Nov 6, 2016 at 1:59 AM
SATURNTECH9
  • 30,869 POSTS
Your welcome were here to help tell all your friends about us.
Nov 6, 2016 at 1:35 AM
