2004 Kia Optima OXYGEN SENSOR
JVILLANELLI
  • 2004 KIA OPTIMA
  • 6 CYL
  • FWD
  • 185,000 MILES
HOW DO I REPLACE THE LOER AND UPPER OXYGEN SENSORS
Monday, April 5th, 2010 AT 11:12 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Once, you've located the oxygen sensor to be replaced, spray the threaded area with a penetrating lubricant. While the lubricant loosens the connection, carefully disconnect the wiring harness and place it aside.
Using a flared or box-end wrench, loosen and remove the old sensor.
New oxygen sensors usually come with a special anti-seize compound applied to the threads. Simply position the new sensors in the threaded hole and tighten in place. There's no need to over-tighten the sensor-just past hand tight should be fine. Once the plug is in place, re-attach the wiring harness.
Friday, April 30th, 2010 AT 9:40 PM
