2004 Kia Optima Keeps Running Hot after repairs
2004 KIA OPTIMA
DIANE GRAY
Engine Cooling problem
2004 Kia Optima
My thermometer water pump hoses and timing belt were replaced and the hand still goes into the red when I drive for a while and then Idle. There are no leaks around the hose, they burbed the radiator twice and found no leaks. The coolant level is staying steady. I am expected to go back for visit number 6 in less than two weeks to see if they can diagnose. What are they missing?
Someone told me there is a sensor that goes out when the thermometer is replaced but they keep saying that it does not need to be replaced.
May 26, 2010 at 7:37 PM
  • 31,937 POSTS
Hi there,
I presume that the cooling fans have been checked, so i would be looking at the radiator, have they cleaned it? a back flush is not good enough, it will have to go to a radiator repair shop and have the cores checked and cleaned, you may have a number of blocked core tubes, i would get this done first.
mark (mhpautos)
May 27, 2010 at 1:17 AM
