Engine shut off while driving?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,666 POSTS
It sounds like you have a vacuum leak. Here are a couple of guides to help you confirm the problem and get it fixed:
and
https://www.2carpros.com/articles/stall-at-idle
We should also run the codes to see what comes up.
Please let us know what you find.
Cheers, Ken
Monday, September 7th, 2020 AT 2:30 PM (Merged)
ERFENDE
  • 2001 KIA OPTIMA
  • 4 CYL
  • FWD
  • 189,000 MILES
My car has been recently stuttering when at idle then dies. Sometimes it doesn't do it. If I unplug my MAF it stops. I'm not sure if it is possible to drive without a MAF plugged in for a long time. I have replaced the MAF, 02 sensors, and filter. I have cleaned my MAF as of 20 mins ago and it ran fine then I turned it off and tried again and it jumped so bad it felt like the transmission was about to fall out. I also cleaned the Intake Air control valve and the throttle body.
I also replaced my radiator yesterday as well, it had some kind of gook (almost like stop leak) all in it and it wouldn't come out even after flushing it. So I just replaced it. I only need this car til February, then I am getting a new one and can afford to work on this one over time. Any help would be greatly appreciated.
KHLOW2008
  • 41,814 POSTS
Hi erfende,
Thank you for the donation.
Does the Check Engine Lamp indicates and did you try to retrieve for trouble coes?
Since you have unplug sensors, there could be false trouble codes so erase all trouble codes and after a test drive, check for trouble codes again.
Let me know what you find.
MIKE H R
  • 3,094 POSTS
Old school reply, use some fuel additive. There may be some setements in the fuel tank that cuts down on fuel supply to the engine. Also I would change the fuel filter, those are the cheapest and most sensable things to do.
BOWSER12
  • 2001 KIA OPTIMA
  • 151,786 MILES
Every time my car sits out in the sun or when its hot out, when I drive it, my RPMs will fluctuate from normal, which is around 2000, up to 3000 and down to 0 then back to normal. Sometimes is stays at 0 for a few seconds before shooting back up. A few times I've even had my engine totally quit on me and I can't get it started back up unless I let it sit for a little bit. I was just wondering if you could tell me what could cause it to do this.
Monday, September 7th, 2020 AT 2:31 PM (Merged)
  • 109,936 POSTS
My first suspect would be the idle air control valve (IAC). The IAC is responsible for maintaining the engine idle speed. However, you said normal is around 2000 RPM's. That is extremely high. It should be around 900.
