key fob transmitter location
125,000 MILES • 0.7L • V8 • 2WD • AUTOMATIC
OMARFAKHOU
where is the transmitter for the key fob located on the E-350 van? no seats
it is an ambulance.
thank you
Aug 26, 2017 at 12:11 AM
STEVE W.
  • 15,418 POSTS
The factory location for the RKE module on the E-Series would be behind the drivers side B pillar. If this is like most ambulances I have worked on you will likely need to remove the seat to get to the trim panel behind it. Then search through the three to four modules in there to find it.
What is the problem you are having? Be advised that you cannot just remove the module, that will disable multiple items.
There are a few TSBs on the system and programming in the remotes is not hard.
To program (or re-program) transmitter(s) into the electronic door lock control, perform the following steps:
1 Turn the ignition switch to the "on" or "on/acc" position and short the two terminals of the program connector located below the driver's side of the instrument panel at the base of the steering column. All doors should lock and then unlock.
2 Press any button on each transmitter, (one at a time). All doors should lock and then unlock. If the door locks do not respond, press the button again (up to three times maximum with the same transmitter).
3 Repeat step two to program additional transmitters into the control module (up to four transmitters maximum).
4 Turn ignition switch off. All doors should lock and then unlock.
5 Make sure the short has been removed from the program connector J2.
Aug 26, 2017 at 2:08 AM
