After changing the battery in my key fob it does not work
114,000 MILES • 2.8L • AUTOMATIC
ROSEMARY ADAMS
I just had the battery changed on my key fob and now it does not work. it will not lock or unlock the doors. how do I get it to work now?
Jan 24, 2018 at 5:16 PM
STEVE W.
  • 15,398 POSTS
Okay, I am going to assume it worked prior to the battery replacement? Double check that the battery is installed correctly and use a pencil eraser to gently clean the contacts for the battery.
Do you have a second fob to confirm that it is actually a fault with the fob and not something on the van?
If it is a bad fob you will need a dealer or automotive locksmith to try to reprogram the fob. Usually the locksmith will be cheaper, faster and 99% of the time you do not need an appointment. They can also verify that the remote is the problem.
If it is a bad fob you can usually get a new one cheaper online. New is highlighted because used can be a big waste of money when they do not work or the system will not recognize them.
Jan 25, 2018 at 9:19 AM
