2003 Chysler Grand Voyager Motor in device under bodywork,
40,000 MILES • 4 CYL • 2WD • MANUAL
GORDON_HEWITT
I have been having terrible problems with the battery losing charge over 36 hours. When you switch everything off and leave a multi-meter in between the disconnected earth lead, there is next to no draw. During the night, something fires up and the battery goes flat.
Recently we found that when we reconnected the battery following an external charge, there was an electric motor, whiring noise coming from beneath the vehicle under the rear sliding door. There is a small device there with what looks like a 1/4-1/2" exhaust pipe-vent. Since disconnecting this the battery has kept it's charge.
What is this thing and why would it come on in the middle of the night when the car is locked and everything turned off?
Mar 4, 2008 at 8:23 AM
  • 110,248 POSTS
Hi:
Is it possible for you to take a picture and upload it to me? I'm not sure what it is without seeing it. It may have something to do with the ABS, but I need to see it.
Oct 8, 2008 at 11:40 AM
