Not sure if your came with the vehicle or is an aftermarket. Try this, remove the negative battery cable for about five minutes, and replace, be careful. Make sure all of the accessories and such inside the car are off, because you may receive a little spark, just enough to scare you not shock you. And also be prepared to use the remote to shut the alarm off. Because it may go off. Try that first. If not then, if it is an alarm that was manufactured with the car, then the fuse box on the drivers side, or under the hood will have a labeled alarm fuse.
SPONSORED LINKS
Wednesday, July 14th, 2010 AT 10:53 AM
