Keeps shutting off?
350,000 MILES • 3.8L • AUTOMATIC
2THESTARS
Hi, I just sent you a question last week actually, thank you for answering. that it was very helpful. so, I have since then replaced my alternator, bought a new alternator yesterday and had it put in the car. As soon as it was put in the car, the car still would not start. took the battery charged, it started but immediately shut off. got the car jumped off shut off again. took the battery had it charged completely was able to drive it almost home and it shut off again and would not start without being jumped off but would immediately shut off again. okay, so, we took the battery he had it completely charged again was able to drive the car home. I thought everything was fine. the auto parts place check the battery, they said oh, it has a dead cell but the battery is okay. I don't know what that means or anything. all I know is that my car is now stranded on the side of the road actually right now because it won't start and honestly is not think it's going to do any good to get it jumped off again. so, do I need to take the alternator back off and see if it's a bad alternator or do I just need to buy a new battery or is it something else all together? please help, I just don't know what to do. thank you
Oct 21, 2022 at 4:59 PM
AL514
  • 5,700 POSTS
Hello, if the battery has a bad cell it needs to replaced. The battery is made up of 6 cells that act together as one battery, but cells can eventually get shorted together and this cuts the battery down to really only 5 cells. or less. So, a load test with a multimeter on the battery will give its voltage.
If you're having this much trouble with the vehicle, and it is a battery issue, just checking the battery voltage with the vehicle not running will most likely show low voltage. It is also possible the alternator you installed was bad.
These components are just rebuilt parts and if they are not fully checked before they are sold, a bad part can be sold, it happens all the time. An alternator that has bad diodes for example will eventually damage the engine computer and other modules. There are some guides below to help with any testing needed. They are pretty easy tests. Just checking voltage readings with a basic multimeter. Let us know what you find and if you have any other questions.
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Oct 22, 2022 at 3:04 AM
