Will not shift gears when engine is warmed up
95,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
ANDREW SHELDON
  • 5 POSTS
Car runs fine until it gets warm. then it will not shift gears, press accelerator and it just revving the engine and not going anywhere. i shut it off, wait a couple minutes and it starts up and goes for awhile and does it again. every time i shut it off it starts right back up and goes until it happens again. I just replaced the transmission front seal.
Jan 22, 2018 at 6:57 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Is the fluid lever okay?
Will it move in reverse?
These are the possible causes:
Trouble shooting, symptoms, vehicle does not move in forward gears or reverse.
Shift cable, control valves, fluid level, oil pump and torque converter.
Trouble shooting, symptoms, vehicle does not move in forward gears or reverse okay.
Control valves, forward clutch, one-way clutch (sprag) and forward clutch oil supply (blocked).
Jan 22, 2018 at 7:43 AM
ANDREW SHELDON
  • 5 POSTS
When it acts up it will not go in reverse. Transmission fluid level has not differed much.
Jan 22, 2018 at 11:43 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
What do you mean by "transmission fluid level has not differed much."?
Especially the word "differed"?
Did you check the level?
Jan 22, 2018 at 9:55 PM
ANDREW SHELDON
  • 5 POSTS
Differed as in it is not losing any.
Jan 23, 2018 at 4:10 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Okay, but you just replaced the front seal which means you had to remove the torque converter, so if any fluid spilled out you would have to add some.
So, is the level full right now?
Jan 23, 2018 at 4:35 AM
ANDREW SHELDON
  • 5 POSTS
Yes it's full
Jan 24, 2018 at 5:32 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I suppose you replaced the front seal because it was leaking.
Chances are if you had a leak, at time you probably ran empty on fluid and might have worn clutch material, that dropped down into the pan and might now be actually clogging up the filter thus shutting off the fluid from being drawn in and pushed through by the pump.
If you remove the pan and see a lot of debris in the pan, either stuck to a magnet and/or clogging up the filter, change the filter and install a new pan gasket, and refill with fresh fluid once you get the pan back on and try that.
If it still doesn't move, let me know and if there was a lot of debris in the pan, also let me know that.
Jan 24, 2018 at 5:55 AM
ANDREW SHELDON
  • 5 POSTS
Sure will thanks
Jan 24, 2018 at 2:41 PM
