Pulled up to gas station got gas tried to start truck will not start. I have spark and fuel I have replaced MAP sensor, pickup coil, distributor cap, ignition module and rotary button. When I turn it over the injectors are spraying out fuel on both sides equally. I checked for compression at the number one cylinder with my thumb it blew my thumb out. I checked to see if rotor on distributor was turning when the vehicle was cranking over and it was. I can hear fuel pump kick on when i turn the ignition over I also checked all my fuses they are good. I tried spraying starting fluid in throttle body still no start. I pulled my plugs out they were not burnt just smelled like gas. I am going to replace the plugs and see if she will fire up. I am getting spark and fuel I just do not have a clue why it will not start. Please help.
Sep 29, 2017 at 5:26 AM
