1993 Jeep Wrangler Brake Lights Out
UNICE501
My brake lights in my 1993 jeep wrangler automatic 4.0 liter 4x4, don't light up when I brake, and I have not been able to find the switch everybody tells me there is please, help mw with this problem. I have order a repair manual but i have not recieved it yet. I would really apreciate if you can help me with this problem, I have checked the light bulbs and the fuses and did not find a problem there. Thank you. EUNICE
Jun 13, 2007 at 12:38 PM
UNICE501
mileage is 150,000 1993 jeep wrangler 4x4 4.0 liter automatic. I already gave the information please help me. Thank you
Jun 13, 2007 at 12:46 PM
UNICE501
I already donated and you have not anwered my question yet. What do I have to do for you to anwer my question, please let me know
1993 jeep wrangler 4x4 automatic 4.0 li 150,000 miles and the problem is the brake lights don't light up when I brake, there is no problem with the fuses or light bulbs they're all been checked.
Jun 13, 2007 at 1:07 PM
2CARPRO JACK
  • 11,533 POSTS
If you follow the brake pedal arm up into the dash there is a switch mounted on it.Should have power at one wire and the other one should power up when the brake pedal is pushed.
Jun 14, 2007 at 1:17 AM
Suggested Repair
Locate the brake light switch mounted on the brake pedal arm under the dash. Confirm one wire has power and the other receives power when the brake pedal is pressed.
Conversation Summary
The owner of a 1993 Jeep Wrangler says the brake lights do not come on when braking. The bulbs and fuses were already checked and found okay. The expert says the switch is mounted on the brake pedal arm under the dash and should have power on one wire, with the other powering up when the pedal is pushed.
