93 wrangler headlights going out, coming back on
BAABAABLACKJEEP
I have a 93 Jeep Wrangler, 4.0 Standard trans with 90,000 miles. My High beams will go out while driving then come back on a second later. It is only my headlights, not tail or marker or park or dash. Sometimes it happens right away and sometimes i can drive for hours without it happening. My low beams seem to be less affected.
Aug 9, 2007 at 8:29 AM
BRUCE HUNT
  • 3,754 POSTS
You definitely need to be scurring around for the grounds. This sounds like grounding issue. There should also be a relay and it could be a problem as well. The relay is usually in the fuse box area and could even be in the fusebox under the hood. Problem is that when you go to test it, it will be fine.
Aug 9, 2007 at 8:44 AM
