91 Wrangler gauge cluster and fuel tank
SCOTTY000
  • 10 POSTS
hello, i have a 91 wrangler,6cyl. with about 150,000 mi. on it, the gauge cluster quit working all of a sudden, the rpm,temp,oil press,fuel,battery, none of those are working now, the speedo and clock still work, i have pulled and visually checked every fuse on the vehicle they all appear to be good. i dont know what else to check. it was working fine and then on a kind of rainy day i cranked it up and the gauges quit working. i just put a new ignition and key assembly in right before this happened but it was working fine after i got done. got any ideas what it may be ? i also have one more question, i am haveing trouble putting gas in the vehicle,it seems every time i go to fill up i have to run the pump at a very low volume to keep it from backflowing and shutting the pump off, i checked the filler neck and vent hose for kinks but they are fine. ????????
May 31, 2007 at 6:24 AM
2CARPRO JACK
  • 11,533 POSTS
Double check the adjustment on the ignition switch (electric part not tumbler) Leave fuses in, key on and check them with a test light. Couldnt find any TSB'S or recalls about the filler neck problem. Might want to call Jeep and ask them about it
Jun 1, 2007 at 12:32 AM
SCOTTY000
  • 10 POSTS
are you talking about the switch at the end of the ignition rod down under the dash on the lower part of the steering column ? and your saying to check the fuses with a test light while they are still plugged in ? just trying to make sure i am understanding, thanks, scotty
Jun 5, 2007 at 3:34 AM
2CARPRO JACK
  • 11,533 POSTS
Yes on both
Jun 5, 2007 at 10:12 AM
