2004 Jeep Wrangler oil pan gasket
2004 JEEP WRANGLER
80,000 MILES • 6 CYL • 4WD • AUTOMATIC
CODYMAC22
how do i change my oil pan gasket? do i need to disconect the headers because the exaust run around my oil pan.
Dec 28, 2008 at 4:57 AM
JASONRAY
  • 213 POSTS
Don't disconnect the exhaust manifold from the head. Just disconnect the exhaust pipe from the header. You may have to disconnect it farther back, as well and remove it completely to get it out of your way. I don't. I just pull it down out of the way but I work on commission so I try to find all the short cuts I can. You may have to disconnect the motor mounts, though, and raise the engine up just a little so it will clear the bell housing on the transmission and the front axle.
Dec 28, 2008 at 5:21 AM
