1987 Jeep Wrangler Oil Pan Gasket
1987 JEEP WRANGLER
153,000 MILES • 6 CYL • 4WD • MANUAL
CAMERO915
What in involved in replacing the oil pan gasket. This Jeep has been lifted.
Oct 26, 2009 at 7:03 AM
  • 110,244 POSTS
It's been awhile since I did one. A body lift won't help access the pan. The engine will need to be lifted to remove the pan. If you disconnect the motor mounts, there should be enough room to lift the engine to remove it.
Nov 10, 2009 at 5:37 AM
