2002 Jeep Wrangler lights
2002 JEEP WRANGLER
75,000 MILES • 6 CYL • 4WD • AUTOMATIC
RODLEOPARD
my pull out fog will not stay in and its draing my battery, so i disconnected them, but i am still getting the bell alarm and my battery is still being drained, so i was wondering where to start looking for the problem. also when my battery is daed, after i jump it off, the motor will not idle but will go dead until it gets charged for a little while.
Jun 4, 2008 at 6:06 AM
BREWER
  • 34 POSTS
first problem - the switch is probably your culprit on the fog lights. that's where I would start.
second - batteries don't like being run dead. They generally can handle it about 4 times and then they becoem duds. If your battery was drained and boosted more than 4 times, you probably have a dud battery that now cannot handle holding a charge anymore. I would have that checked out, and probably replaced. If the switch isn't the problem, and you've changed the battery - good idea when you shut off the vehicle to disconnect the battery to prevent it from being drained until you solve that problem too.
Jun 8, 2008 at 11:02 AM
