HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Jeep
Wrangler
Engine
Symptoms
Stall at Idle
1988 Jeep Wrangler Won't idle
1ST SGT
MEMBER
1988 JEEP WRANGLER
6 CYL
4WD
MANUAL
44,500 MILES
Jeep won't idle below 1000 rpm. It will surge then die. I replaced the EGR valve but that didn't work I need help. Thanks
Monday, January 14th, 2008 AT 6:41 PM
BLACKOP555
MECHANIC
Clean out your throttle body and IAC. Also check the electrical connectors on it.
Monday, January 14th, 2008 AT 7:37 PM
Please
login
or
register
to post a reply.
Related Engine Stall At Idle Content
Won't Idle And Stalls Out When Driving Also Misses
Had My Jeep For About A Year And Rarely Drive It. It Misses, We Thought It Was The Distributer It S Not, It Will Idle All Day In The...
Asked by
ronronjohn56
8 IMAGES
1988
JEEP WRANGLER
GUIDE
Engine Stalls After Dead or New Battery
So you installed a new battery and now the engine stalls? You have done nothing wrong because believe it or not this is normal. The engine computer has a learning cycle...
Stalls At Idle
Stalls At Idle, What Should The Vacuum Be? This Is A Carburetted 4.0.
Asked by
Joe McGregor
1989
JEEP WRANGLER
1998 Jeep Wrangler Engine Light On Will Not Idle
My 98 Wrangler All Of A Sudden The Engine Light Came On And It Will Not Idle. I Have To Give It Gas To Sart It, And Also Need Tokeep Foot...
Asked by
pbbob
1 ANSWER
1998
JEEP WRANGLER
Jeep Starts Then Dies After 10 To 30 Seconds
Vehicle Starts Then After A Very Short Period Of Time Just A Few Seconds. It Has Spark, The Fuel Pressure Is Good As Well As The...
Asked by
Justin Roll
1 ANSWER
2 IMAGES
1991
JEEP WRANGLER
Stalls In Drive Only When Engine Is Cold
I Replaced The Idle Air Control Valve In Is Not Workingo
Asked by
kapulica
1 ANSWER
2001
JEEP WRANGLER
VIEW MORE
Stalls at Idle
Oil Change and Filter Replacement BMW 525i
Spark Plug Replacement Honda
