2002 Jeep Wrangler bad gas?
2002 JEEP WRANGLER
15,900 MILES • 6 CYL • 4WD • AUTOMATIC
MASHIP
car runs but intermitantly will cough or shut of sometimes will start right away other times i have to wait up to 10 to 15 min. we replaced fuel pump, filter assembly which was in gas tank ran good for awhile then started same thing again is there another exterior filter we need to change or should we drain all the fuel?
Aug 22, 2010 at 3:54 PM
CJ MEDEVAC
  • 11,004 POSTS
See my profile...Imma CJ GUY
Won't hurt nothing to try this,
2 bottles of a product called "HEET" into your gas tank----extra is no big deal
Basically does the same as using "Denatured Alcohol" to MIX IN or dissolve the water into your existing fuel.
Available at parts stores----ask if they now have anything better than "HEET"
Hope it's that EZ
Reply with good news
The Medic
Aug 22, 2010 at 5:01 PM
MASHIP
thanks for your quick reply. We did add 2 dry gas still had the same problem it ended up being a crank position sensor thanks for your assistance!
Aug 24, 2010 at 5:34 AM
