2000 Jeep Wrangler My jeep will randomly die while driving
2000 JEEP WRANGLER
95,000 MILES • 6 CYL • 4WD • MANUAL
WMARTINHICKMAN
My jeep died a few weeks ago. I had it towed to a shop, where it cranked fine, and the diagnostics said that the fuel pump and fuel regulator were bad. So I replaced them. Then it kept dieing and not cranking, so I put a crank shaft possision sensor on it. That didn't work. The dealership ran a diagnostic and they said the fuel regulator was bad because the fuel pressure kept dropping. Now the mechanic says I need a new instrument cluster. What is actually wrong with my Jeep????
Apr 10, 2009 at 12:40 PM
  • 110,244 POSTS
If the fuel pressure keeps droping, it could be the fuel pressure regulator or the pump they replaced. That could cause the problem. Why did they say the inst. panel needs replaced?
Jun 29, 2009 at 4:12 PM
