Brakes problem
2000 Jeep Wrangler 6 cyl Four Wheel Drive Manual
why would brake lights stay on when the jeep is off
Saturday, May 23rd, 2009 AT 10:24 AM
MECHCURT
MEMBER
Down on the brake pedal up under the dash there should be a brake light switch. When the brake is depressed the switch turns the brake lights on. Sometimes this switch gets moved or just quits and the lights stay on. That is where I would check first. You can manualy trip it and have someone watch the lights and see if it is functioning properly. Hope this helps Curt
