2000 Jeep Wrangler Brake lights not working
KENRF
  • 2000 JEEP WRANGLER
  • 6 CYL
  • 4WD
  • MANUAL
  • 115,000 MILES
The brake lights do not work. The turn signals in the tail lights are working. Tail lights do work. The cruise knock off does work when the brake pedal is hit. The fuse for the brake lights has been confirmed good.
Tuesday, December 2nd, 2008 AT 6:59 PM
Do you have the high mounted brake lite?
Test the turn/hazard switch which is part of the multifunction switch the brake circuit goes there before it gets to the lower brake lites.
Tuesday, December 2nd, 2008 AT 7:27 PM
