1999 Jeep Wrangler
DANE63
  • 1999 JEEP WRANGLER
Computer problem
1999 Jeep Wrangler 6 cyl Four Wheel Drive Automatic
i've changed ignition switch, crank sensor. This jeep will crank & run great. Then next day it won't even crank. I'm chasing a ghost please any info
Thursday, February 11th, 2010 AT 10:39 AM
CJ MEDEVAC
  • 11,005 POSTS
Recently I was installing a manual throttle control on my CJ (like a cruise control, only choke cable controlled), my NEIGHBOR was helping, PIDDLING around. When I finished, he had left........NO CRANKY UPPY !!!!.......Went thru system for starting. Checked In an orderly fashion all EZ stuff.......went to SOLINOID to check for 12V at "S" terminal when key in start position................Years ago I moved solinoid to rear of fender, to make much needed space for my train horn................NEIGHBOR GUY accidentally BARELY knocked "S" wire partially off of it's stud......When he Pulled my somewhat hard to get to DIPSTICK while messing around...............check fuses......wire connections (buddies messing w/ stuff).....look at troubleshooting in a HAYNES or CHILTON manual........Reply....CJ guy may help if I can...................Love Turddog
https://www.2carpros.com/forum/automotive_pictures/411289_100_0328_1.jpg
Sunday, February 14th, 2010 AT 11:22 PM
