1994 Jeep Wrangler ENGINE STOPS RUNNING WHEN HOT
JAY ADKINS
  • 1994 JEEP WRANGLER
Engine Performance problem
1994 Jeep Wrangler 4 cyl Four Wheel Drive Manual 120K miles
STARTS UP AND RUNS FINE UNTIL IT GETS WARM, THEN IT JUST SHUTS OFF WITH NO WARNING.
ALL OTHER POWER REMAINS ON, IT DOESN'T START TO JERK OR SPUTTER BEFORE IT QUITS, IT JUST SHUTS DOWN WITH NO WARNING.
AFTER 5 OR 10 MIN'S IT WILL START BACK UP AND RUN FOR A FEW NORE MIN'S.
DO YOU HAVE ANY IDEAS AS TO WHAT COULD BE CAUSING THIS? YOUR HELP WOULD BE GREATLY APPRECIATED.
THANK YOU IN ADVANCE FOR YOUR HELP.
Friday, July 11th, 2008 AT 1:50 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
What is your oil pressure? Does the engine overheat? Check the EGR (if equipped). Some other less likely possibilities are a vacuum leak that only occurs at a higher temperature or a bad alternator.
Tuesday, July 15th, 2008 AT 10:16 PM
